Old 12-11-2013, 04:59 PM   #1
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by bam914 View Post
1 crank scraper bolts
2 timing chain guide bolt o rings
3 case to carrier bolts and swirl pot o rings
4 not sure I use them for the cam and crank sensors
5 ?
6 only need one and it is for the oil fill tube
7/8 heat exchanger seal
9 oil pump housing
10 vario solenoid early 5 chain
11 oil filter housing
12 oil pick up
13 ?
14/15 coolant passage seals
16 AOS return
17 dip stick tube
Ok, what is a "crank scraper"? On this forum I shudder to think of the possibilities.
