Old 12-11-2013, 04:06 PM   #4
woodsman
woodsman's Avatar
Originally Posted by Dave2001S View Post
It seems fluid is leaking out of the washer fluid reservoir bottle. I've checked all over under the frunk and removed the trim panels to have a look, and I see no leaks there where the reservoir fill tube goes in, or anywhere else. Yet fluid seems to pour out under the car if I refill the reservoir. Can someone tell me how to check where the fill tube attaches to the reservoir bottle? For that matter, where is the reservoir bottle itself? It doesn't appear to be very accessible either from under the car or through the wheel well or via the frunk! Thanks!
Just below the fill cap, a line connects to the reservoir . I think it's made of plastic and needs to seal with the reservoir. I found that gently pulling on them caused them to snap into place and the leak stopped.
