Old 12-11-2013, 07:05 AM   #10
The Radium King
The Radium King's Avatar
if you just want the pse to be on/off with a switch, use an electric cutout instead of vacuum. vacuum is used when you want fast response (ie, actuating as you cross an rpm threshold); electric should serve your needs fine, is cheap, and is readily available on ebay. check out maxspeed motorsports who sell such a kit.
