Old 12-10-2013, 08:07 PM   #1
epapp
epapp's Avatar
SAI doing something weird
I know the SAI pump is supposed to come on for 30 or so seconds on a cold start, which mine does, and then shuts off. However if I drive for a few blocks after the pump initially shuts off, and come to a stop light (idling for more than 15 seconds or so, coolant still <100F), the pump will turn on for about 3 seconds and then shut off. Is this normal? The pump won't come on again, even if I were to stop just another block away and let it idle.
I hope my SAI ports aren't as dirty as that guy in the sea foam threads are
epapp is offline   Reply With Quote
