Originally Posted by Walter White
Hi James,
I am curious about the inside diameter of the IM shaft, the tube, behind the bearing. Do you have means to measure that?
As close as I could measure was 34.25 mm. I'd put +/- 1 mm on there for tolerance as the measurement was not straightforward.
