Old 12-09-2013, 04:19 PM   #1
evifenocvt
1999 2.5 engine + ancillaries
any interest out there in a 2.5 long block with ancillaries? approx 102k miles. engine suffered from failed heat exchanger and there was oil in the cooling system.
i drained the oil pan and found no traces of coolant in the oil. also pulled both heads and examined for cylinder sleeves cracks. no cracks found in the sleeves or cylinder heads. really looks to be an isolated case of a failed oil separator. the heads are pulled so you can examine them and the short block closely for any signs of damage.
comes with everything as directly dropped from the car, minus the ac compressor, AOS (which was shot) and of course oil separator (which failed.)
asking $1,000.
evifenocvt is offline   Reply With Quote
