Thread: Rear tires
Old 12-07-2013, 09:16 AM   #2
Topless
Track rat
Topless's Avatar
To get the most out of your car it's best to stay within the same tire class with very similar grip levels and wet performance. With DZ101s on the front I would probably choose from these tires:
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=UHP
Putting Hankook V12s on might work fine but I expect them to have a bit more wet and dry grip resulting in a little more understeer while cornering. It will still be safe to drive but you might not enjoy running two different tires.
Here is a tire Rack test video with the V12s:
http://www.tirerack.com/tires/tires.jsp?tireMake=Hankook&tireModel=Ventus+V12+evo+K110
And here is the DZ101 tested:
http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=97
