Old 12-06-2013, 03:33 PM   #24
Jager
Jager's Avatar
Originally Posted by moresquirt View Post
Jager,what year and model do u have?
Unbelievable,if u have the time can u list what u had to do for maintenance,is it the original top.
I have a 2001 base model with 2.7L
Here is what I have done (or had done) since purchased in 2004 (miles are approximate):
Replaced windshield – Pro installed
Replaced rag top (cracked rear plastic window – don’t operate the top in cold weather) – Replaced myself
Replaced brakes and rotors – Myself
Replaced the battery -Myself
Replaced fuel pump (going bad) – Pro
Replace Air Oil Separator – Pro
Replaced the ignition switch -Pro
Replaced water pump (leaking) – Myself
Replace gas cap (seal cracked) – Myself
Replaced Air Oil Separator again (DO NOT OVERFILL MOTOR WITH OIL) - Myself
Replaced IMS Bearing, rear main seal, clutch, and the flywheel – Myself (204k miles)
Replaced all O2 sensors – Myself
Replaced front motor mount - Myself
Replace mass air flow sensor (no issues, now I have a spare) - Myself
Replaced all spark plug coils (no issues, preventative maintenance) - Myself
Replaced the seals on the oil cooler (no issues, preventative maintenance) - Myself
Replaced turn signal/cruise control switch group – Myself
Replaced headlights (entire assembly) – The plastic lenses had serous road rash after 200,000 miles
Replaced covers to the key fob remote controls - Myself
Replaced hood and trunk lift struts – Myself
Replaced driver’s side window regulator and locking switch – Myself
Replaced the front bumper (I hit a coyote) – Pro
Replaced the secondary air injection system cut-off valve, vacuum reservoir, electric cut-off switch – Myself
Replaced brake pads and rotors again @240k miles – myself
Replaced the rear track control arms- myself
Replaced the trailing arms - myself
Replaced the rear struts and top mounts – myself
Replaced IMS bearing at 243,000 miles with LNE bearing… Again.
Replaced water pump 243,000 miles
Replaced evaporator valves
Replaced rear wheel bearings 245,000 miles
Replaced both axles 245,000 miles
Replaced front wheel bearings 250,000 miles
Replaced catalytic converter (bank 2) 253,000 miles
I change the oil every 3k - 4k miles and drive it hard!
Jäger
300K Mile Club
