Thank you for the quick responses. I'm going to order the ignition switch today from p.p. and I'll try to find a way to fit my post-thanksgiving big body under there. I may end up removing the seat, and I will also grind down an old flathead to squeeze in there. Its about time for a service so hopefully that makes the oil level sensor happy again when I change it this weekend. Thanks again! I hope this fixes it:dance:
Is it possible to test the ignition switch with my durametric?
"This all started with a simple oil change..."
Reason: additional question added
