Thought I might be able to help out a bit.
I ran mine up into the license plate light, and in the trunk through the (driver's) left rear tail light. Past that you snake it through and around the trunk wiring and poke a small hole into the compartment by the let side engine deck lid, run down along the driver's side o the passenger compartment and through the console.
Be sure to allow enough 'slack' in the cable to route around the engine access portal. I taped the cable and then taped it in place to ensure it did not snag anything.
Good luck! You will enjoy it! One of the those mods that has 'real world' application due to the relatively poor visibility out the back!
