Old 12-02-2013, 04:59 PM   #12
BYprodriver
BYprodriver's Avatar
Originally Posted by tconnarn View Post
My 2004 S Model seems to be doing the same thing. it takes a few times of turning the key before i get any sound from the engine. just took it to autozone to test the battery and their computer said that the battery, alternator, and starter were all ok. did it end up being the fuel pump? its cold here this week. i was wondering if that had something to do with it? also the front trunk isnt opening properly. im not sure if its related?
Thanks for searching before posting. If you have to turn the key multiple times before the starter engages it's usually a sign your ignition switch is going bad. Common problem.
