Old 12-01-2013, 04:50 PM   #20
drbodzin
San Diego Boxster
drbodzin's Avatar
Time to get the SC installed. This took about 3-4 hours of trial and error to get all the parts to line up
properly. Had to get the out port of the SC aligned in the right direction. Then had to get the rubber tubes
aligned properly. Lets just say I had to put the thing in and out 6-8 times before I got it perfect. Also had
to shave some metal off the aluminum bracket that mounts to the cam cover to provide the right
clearance and alignment of the out port of the SC. This kit is definitely not just "bolt on" and go.
Installed the check valve per the instructions. This is a tube that runs under the driver's side manifold.
Then I re-installed the oil cooler.
Filling the SC with 2.5 oz of SC oil.
Testing the alignment of the out port piping.
Here you can see the area I had to remove some of the metal from the bracket.
Showing the out port alignment.
Here is the SC installed with the in port piping installed.
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
