Originally Posted by Stiletto Pat
Mountainman,
Are you saying that this will bolt onto the stock Porsche exhaust manifolds with the 1st set of stock cats, and replace the balance of the exhaust system from that point back? Thus, one would end up with the stock manifolds, stock cat #1, and an entirely new system from that point backwards?
Please advise, as this might be the immediate solution for me.
Thanks,
Pat
Pat, Yes, as johnny said, you retain the primary cat which has both o2 sensors attached and everything from there back is replaced. Saves a bunch of weight off the rear end. Takes about an hour and a half to change out. I wish it would fit my 987, I'd just switch it over. The wife doesn't drive it.
