Originally Posted by drbodzin
Thank you both for the clarification. That helps a lot.
Today I got under the car to start the install of the bracket that mounts on the can cover. Easily removed the header to make room to work.
On inspection of the cover, there are two areas (orange arrows) blocking the bracket. In the image from iA, the cover does not have these.
Seems the only way to get the bracket to fit would be to cut these off the cam cover.
Turns out I was able to grind off some metal from the bracket and it fit perfect.
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
