Old 11-29-2013, 11:15 AM   #35
drbodzin
San Diego Boxster
drbodzin's Avatar
JAAY and Radium King, thank you so much for your input. Both help a lot.
So it sounds like I can either:
1. Install the Wide-Band O2 sensor and use a Apexi AFC and have an experienced tuner set the programming.
OR
2. Have a DME reprogrammed. Do I still need to use the Wide Band O2 sensor with this option?
Is the resistor used in both 1 & 2?
For the wide-band O2 sensor, are you replacing the stock ones, or adding it as a 5th sensor?
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
