Old 02-13-2006, 09:48 AM   #8
KRZTACO
Originally Posted by hdpt73
if you decide on a boxster, best upgrade you can do is an engine swap (911 engine). then you will in the the 13's all day long. other then that there are plenty of upgrades you can do cosmetically interior and exterior wise, a sound system would be challenging but is very possible.
That is correct. You need to get an engine swap from a 911. You'll run low 13's all day long with everthing basically OEM. No intake or exhaust aftermarket stuff needed.
If you'd like to tune your stock engine, I highly suggest to avoid it altogether. You'll end up spending more money than a 911 motor swap and be slower and end up with a blown engine. The boxster motors just don't like to be tuned.
Check out the Ruf site: http://www.rufautocentre.com/
or
Scroll down to the Boxster Power Kit
http://www.gmgracing.com/porsche_engine.shtml
KRZ
KRZTACO is offline   Reply With Quote
