Old 11-28-2013, 09:22 PM   #4
Steve Tinker
Steve Tinker's Avatar
Sure, drive them until the brake warning light comes on due to the sensor in the pad detecting that they are worn thin.
Assuming the brake sensors are still connected.....I'm sure you've seen a few removed & tied up in the wheel arch too.
To Scottblue - its relatively easy to see the pads from the rear of the calipers with a flashlight - if in doubt, remove each wheel and you will see the thickness of the pads more clearly.
2001 MV Agusta F4.
