Old 11-26-2013, 07:57 PM   #10
drbodzin
San Diego Boxster
drbodzin's Avatar
Originally Posted by Jamesp View Post
I was just looking through your pictures, and they rock. On your resistor install you might consider using shrink tubing. You'll need to unsolder one end of the resistor and slip the shrink tubing over the wire out of the way, then back up over the resistor after resoldering. Hit the shrink tubing with heat to shrink it. It's a clean solution that looks stock and eliminates electrical tape unwinding over time.
Thanks for the suggestion. I am familiar shrink tubing I did use it on the harness extension to the air pump.
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
