Old 11-26-2013, 05:22 PM   #14
Walter White
Originally Posted by BudmanV24 View Post
A couple of thoughts that I have on this.
While yes the IMS bearing is something that goes out on some cars, I think if you drive these things hard the IMS bearing is the least of your worries.
I have heard this many times and while I do not disagree at all, I think it may very well be a matter of the chains throwing much more oil around and creating much more oil mist in the area of the IMS bearing at high RPMs. At low RPMs, the oil that the chains pick up stay on the chains. So it may still come down to just lubrication.
Chain saw bar oil has ingredients in it that keep the oil on the chain, and not flying off at high RPMs. On our Porsche motors, we want the opposite.
One thing I have thought about. How many ball bearings do you see fail in transmissions, wheel bearings, motor cycle engines, the way IMS bearing fail . While they may wear to a point of needing replacement, I don't recall seeing the complete failures in these bearings that the IMS bearing seems to exhibit. When the bearings are bathed in grease or oil, complete or catastrophic failures are very rare.
Walter White is offline   Reply With Quote
