Old 11-26-2013, 12:52 AM   #9
Nine8Six
Nine8Six's Avatar
OP, you can take off the wheel, then two little plastic clips inside the wheel well, and bend that plastic wheel well lining just enough so you can see the connector on the back of the headlight.
You want to ensure this is aligned properly before forcing anything.
The female connector often (slightly) moves out of place and can become unaligned with the headlight's male connector. If its the case the thing won't lock in place
Luck
