Old 11-25-2013, 08:38 PM   #1
drbodzin
San Diego Boxster
drbodzin's Avatar
Cool Step 2: Installing Resistor in the Mass Air Flow Harness
Step 2: Installing Resistor in the Mass Air Flow Harness (I HAVE REMOVED THE RESISTOR SINCE ADDING THE Apexi AFC)
The SC kit comes with a resistor that needs to be installed on the Air Mass Flow Harness.
Before starting, detach the negative battery strap.
Locate the White Wire with the Blue Strip. Then I spliced in the resistor and soldered it in
place. So far so easy! I should also mention, I had already removed the engine cover
exposing the front of the engine and removed the serpentine belt. Although not
necessary for what's been done so far, I figured I would do all the stuff on the top
of the car before I head beneath.
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
