Old 11-24-2013, 10:50 AM   #11
Nine8Six
Nine8Six's Avatar
Originally Posted by clickman View Post
Fred, do the original high beams still work then after the solenoids are connected, i.e. are the solenoid wires spliced in? Or are they redundant and the only highs are from the projectors?
Norm - See above post from MitchSF. Brilliant isn't it. You'll get far better advice from both Particlewave and MitchSF than I can possibly give you on the conn-wise subject.
Personally, I went to lazy route and simply left the high beam's H7 lamp in there and connected the solenoid to it. Like MitchSF mentioned, flashing during day time is required and this H7 halogen does a good job for that. However, Particlewave is pretty accurate saying it will become useless in night time.
The projector xenon's high beam is brightning up the hell out of everything when the solenoid is activated (high beams ON). Brutal. Outperforms any stock 55w halogen's high beams so you shouldn't miss it too much and very possibly, forget all about old-halogen tech for the rest of your life as well
