					Originally Posted by JFP in PA  ...What you call the "winter setting" (LED is marked with a snowflake) is for the AGM style battery (Optima and the like that require a special charge profile), what you want is the LED with the image of a car (conventional flooded cell batteries). |
I re-read the manual today and the paragraph for the snowflake setting says 'for a battery at temps less than 41 degrees F.  It is also for a AGM battery.
Since my car will be in an unheated area, i think I will use that.
