Old 11-22-2013, 01:54 PM   #12
jaykay
jaykay's Avatar
Originally Posted by Trax View Post
Guys thanks soooo very much for all the help! The solar charger might actually work! Although I always try to cover my car when not is use I'm sure I can hook something up. I was hoping that there was a lithium battery that you could charge in the house and when it's done you just plug it into the cigarette lighter socket till it drains out. Wash/rinse/Repeat.
I think i'll give that solar panel a try. I'm hoping our cig lighter allow for the reverse charging while the key is not in the ignition.
I have tried this as simple solution. You need a diode in that cord otherwise the charge will eventually go the other way.....and blow your cig light fuse. If your car battery is really low you may blow the fuse right away anyway. So this did not work for me. I have a gel cell though
986 00S
