For starters, have you contacted Numeric with your issue? A short cable (under the manifold) is not right.
The cables are not adjusted for the correct "In Gear" neutral spot. That is why it's spiting out of gear under load. Unhook everything on the trany side and shift the transmission manually. See how far each cable is off of "In Gear"and adjust the ends accordingly. You may have to adjust the shifter side as well.
