Old 11-19-2013, 12:00 AM   #2
thejack
Originally Posted by Jamesp View Post
Warm the car up and pull the plastic battery cover in the Frunk - check the two rubber lines behind the battery - if both good and hot then heater core functioning. If not bleed the air out of the cooling system.
If both hot, a mechanical failure in the mixing valve / door is likely.
It most likely depends on bad mixing valves. Find the exchanger valve (hot/cold) and check if it moves as long as you increase/decrease temperature. If the valve's arm moves smoothly but no warm/hot air comes out from the grids, take it down and replace it. You can even try to repair it if you have will and skill.
thejack is offline   Reply With Quote
