By replacing the factory muffler and 2nd cats you will lose around 55lb. The PSS9 kit is also lighter than the standard shocks and springs. If you calculate the HP vs. weight, 100lb lighter in the rear means 1 more HP for you to work with. The air is cooler in Tampa, which where I live. I have not done anything else to the car accept what I posted. I only rev the car up to 2500rpm when launched for 0-60 measurement. I have clibrated the G-Tech already. Most of the people that use G-Tech are posting a .1 second accuracy for the 1/4 mile, so I assume it is pretty accurate. Forget the sound, the power that I gained from the mode is very noticable, specially in the 2nd gear.
MetBlack-S
Factory side skirts
18" Sport Classic
B&M short shifter
IPD Cayman-S Plenum
80mm Throttle Body
FVD Sport Muffler
Fabspeed catbypass
EVO Intake
PSS9
Light flywheel and Sach stage II clutch
Front/Rear Strut Brace
Undetectable K40/3
Rear Defuser
Rear spoiler
