Thread: Dead Windows
Old 11-13-2013, 04:18 AM   #1
NancyH1990
Originally Posted by sb01box View Post
just disconnecting the battery does the reset.
if your car has not been driven in 2 years, the brushes on the motor may have gotten "rusty" and thereby no connection. in this case the only solution maybe to purchase replacement motor. I don't know of any way to "WIGGLE" the motor by forcing the window down or up.
I've not touch the window motor, have tighten the window regul, ator slack.
sorry, I'm at a dead end.
Ooh Ooh. I took the negative of the battery for 3 minutes. As soon as I place the negative back, loud loud loud noise from the rear trunk lock. That ceased as soon as I insert the key.
The rear trunk works fine. But that loud noise was a concern.
Now the driver side window does not go down when I use the latch. Thus the top of the window hits the convertible top. However, unlike the passenger side, I can push it down 1/4" and the window does work.
Any idea? Thanks
NancyH1990 is offline   Reply With Quote
