Originally Posted by tuanle16
thanks. will give a try. also, the right light is malfunctioning. when i turn on the turn signal, the yellow lights turn on and blink, but the white lights don't turn off. any idea how to fix this? only happens on the right head light, the left side works as it is suppose to.
Looks as if there is a faulty LED module on the right-side headlight. If you can't open the unit and get a replacement module alone then you need to ask for a complete replacement right-side unit from your seller.
