Old 11-10-2013, 05:15 PM   #11
Shehadehd
Shehadehd's Avatar
Ipad mini in-dash installation
Having trouble with the radio wiring harness. I am just short on the yellow connector and the black connector. Was your harness long enough to relocate the radio to the lower console? I am going to have to find an extension for mine. My dremel work is complete though!
The wire extension is a *********. To make those plugs long enough I had to thread down down the same side they came from. Even then, they are only long enough to put the radio fully in the lower console and the plug them in. It's a hassle, but I didn't want to extend them.
You can see the wires here:
They went down here:
But watch out for this tab here
The tab is in between the upper and lower console and in the center. Make sure you are leading the wires to the right side so that you have enough left to plug in the connector
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
Shehadehd is offline   Reply With Quote
