Old 11-10-2013, 08:08 AM   #13
kjc2050
kjc2050's Avatar
I installed a Wahler 160* thermostat this weekend (in addition to replacing the water pump and changing the coolant). The coolant is now at ~82*C when fully warmed up and the car is driven a moderate speeds. Prior to this change, the coolant was at ~88*C under the same conditions. Yeah, I know I changed the coolant in addition to switching to a low temp tstat; this was hardly a scientific experiment. But there's little doubt that the engine is running a bit (~10*F) cooler, and I doubt the coolant is responsible.
BTW, used the AirLift to fill the system. What a great product!!!! Took about 90 seconds to get the system to 25 lbs. vacuum; about 3-4 minutes to fill the system, and that included adding more coolant mix to the 5 gal bucket I was using. Worth every penny +++++.
