Old 11-07-2013, 08:15 AM   #1
oldboxster
i just did this job myself, bearing was about $50, took 4-5 hrs, and the time to make a puller die not included, this is a doable job but not for a rookie without lots of tools, for example the nut on the axle takes a 3/4 drive socket with a cheater bar to loosen, and this is just to get started
i ended up doing both, so make sure you have the other side checked. I suppose an axle could be bad but it seems unlikely, good luck
oldboxster is offline   Reply With Quote
