Old 11-07-2013, 06:13 AM   #20
Joe hockin
I changed the strut bearings and re-used the mounts (as they looked and felt perfect)
I disconnected the sway bar to diagnose but the clackety clack persisted. It sounds like loose brake pads...I 've cleaned everything and put blue permatex stop squeal on the back of all of the pads (the fronts had the interlocking piston shims ..the rear doesn't) However, I re-used the anti-rattle springs after cleaning, inspecting, and bending them a bit...everything feels tight.
Joe hockin is offline   Reply With Quote
