Right, forgot to mention the break-in process. I did something similar to what you describe, though not quite as detailed. Just a series of gentle stops with steady pressure with cooling time in between. did it about 10 times in total.
I suspect the problem is due to not changing the pads at the same time as the rotors, but that's just my gut feeling and certainly not an expert opinion.
'99 black 986
