Old 11-06-2013, 08:03 AM   #171
ganseg
ganseg's Avatar
Originally Posted by Kirk View Post
SKF 6204 RSH JEM single row bearing. 2RSH means it has two seals, but obviously I removed one seal. The "RSH"is SKF's new and improved seal. JEM means it has a C3 tolerance to account for thermal expansion. The OEM bearing had C3 tolerances too since the bearing operates in a hot environment, so I stuck with that. The OEM bearing was from the NSK brand, but I prefer and predominantly use SKF at work.
Kirk Bristol
Thanks for the answer, Kirk. I will be looking at the same task in my 2002 S. If possible, please come back to this thread with updates on your actual experience in the future.
I have learned a lot in this thread! Thanks to all who have contributed!
ganseg is offline   Reply With Quote
