Old 11-05-2013, 08:15 PM   #169
Kirk
Originally Posted by ganseg View Post
Which bearing did you install?
SKF 6204 RSH JEM single row bearing. 2RSH means it has two seals, but obviously I removed one seal. The "RSH"is SKF's new and improved seal. JEM means it has a C3 tolerance to account for thermal expansion. The OEM bearing had C3 tolerances too since the bearing operates in a hot environment, so I stuck with that. The OEM bearing was from the NSK brand, but I prefer and predominantly use SKF at work.
Kirk Bristol
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
