Thread: Blown AOS
Old 11-04-2013, 05:27 PM   #3
WhipE350
Autobahn Glanz
WhipE350's Avatar
Originally Posted by germaneighter View Post
Coming home from work last Friday my '02 2.7 5 spd blew a tremendous smoke cloud while under acceleration on an entrance ramp. Immediately pulled over and shut it down although it was not running rough. I was about 15 miles from home and in a sketchy part of town. I let it sit for a few minutes then started it back up. Still smoked but not near as bad. Thought I could limp it home but in a few hundred yards the heavy smoke returned. I shut it down and coasted to a side street. Called the wife to pick me up and went back with the trailer to pull it home. I tried to start it so I could drive onto the trailer but it would not turn over. You could hear the starter engage but could not turn engine over. I suspected liquid lock and hoped for the best. I pulled the coils and plugs and a lot of oil came out of #5. I cranked the engine over and oil came out of cyl #1, #4 & #5. After a couple cranks it would not turn over and the electrical system seemed to go haywire. Clock reset to 12:00. Dash lights flickered. Starter was not making any noise.
Could cranking the engine with coil packs removed cause this?
Ordered a new AOS today. Already had the spark plug tube o-rings so I will do those while in there.
Also, the spark plugs were very tight to remove. The car was two days cold when I removed them. Is this normal?
Is there anything I can do to keep from damaging the cats more than I already have? Will it do any good to disconnect and drain them?
thanks
Was it blowing white smoke? Not sure why you electrical system went haywire, that is strange. Keep us posted I'm curious if you get your baby up and running again. How many miles are on it?
