Old 11-02-2013, 09:11 PM   #1
Daniel R
If the wheel speed sensors are ok (I think it is the rear left sensor that the speedo uses) then the problem will be with the ABS control unit. A good indy will know where to have the control unit repaired.
The spoiler issue is caused by this also. The spoiler operates based on speed readings, which are not working in your car. You can use the switch by the fuse box to operate the spoiler manually, overriding the speed-controlled automatic operation.
Last edited by Daniel R; 11-02-2013 at 09:12 PM. Reason: Confused my left and right
Daniel R is offline   Reply With Quote
