Old 11-01-2013, 11:49 AM   #21
RandallNeighbour
Originally Posted by tanque55 View Post
Are you running stock tires, if not the speedo will be off. I notice that I have a small difference between the analog and digital speedometer on my 2002 the analog showiung a higher speed. Could it be that the road sign is adjusted to show a higher speed ??? Just a thought.
The small difference between your analog and digital speed reading is probably the needle being off a tad (almost calibrated) on the analog gauge.
Mine was off 1-2 mph until I swapped gauge faces on my cluster and drove around the block, came back, removed/reseated the needle, drove around the block, came back, removed/reseated the needle again...
