Old 10-31-2013, 09:38 PM   #13
linderpat
linderpat's Avatar
If you have the standard halogen lights, then the main headlight has 3 bulbs aside from the fog light and turn signal; 1) low beam, 2) high beam, and 3) a small running/parking light that comes on with the headlight switch in the parking light or headlight on position. I'm not sure about the setup in the hid litronic lights, but I know that they also have a small running/parking light bulb that is on with the headlight switch in any on position.
Since it's the easiest to do, I would suggest checking the bulb and the headlight-to-car connector first.
my last post went up before I saw this one. I do have the standard halogens. Thanks for the tutorial. Learned something new. I think it is a simple fix now - just a burned out low beam bulb.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
linderpat is offline   Reply With Quote
