					Originally Posted by EVOL
				 it's no problem if you're only cruising.  if you're planning to "mash" on it, or just want a faster take off, i suggest clicking the "-" to downshift to 1st before taking off.  that's what i do.if you have a habit of putting the pedal to the medal in 2nd gear during take off, it might cause a problem in the long run.
Hi,
      The Tiptronic S
will shift into 1st gear while in Auto Mode (without selecting 'M' and then '-') if you want it to.  When you depress the Accelerator fully, and quickly (Foot on Brake),  you activate the
Kick-Down  Switch which will shift the tranny into 1st while still in Auto Select Mode.
      It normally starts in 2nd because with the Torque Converter (which is also a Torque Multiplier) you won't Lug the Engine, so don't really need 1st gear for a normal start, and it gives the Tip S better MPG...
Happy Motoring!... Jim'99
