Old 02-09-2006, 06:46 AM   #17
MNBoxster
Originally Posted by EVOL
it's no problem if you're only cruising. if you're planning to "mash" on it, or just want a faster take off, i suggest clicking the "-" to downshift to 1st before taking off. that's what i do.
if you have a habit of putting the pedal to the medal in 2nd gear during take off, it might cause a problem in the long run.
Hi,
The Tiptronic S will shift into 1st gear while in Auto Mode (without selecting 'M' and then '-') if you want it to. When you depress the Accelerator fully, and quickly (Foot on Brake), you activate the Kick-Down Switch which will shift the tranny into 1st while still in Auto Select Mode.
It normally starts in 2nd because with the Torque Converter (which is also a Torque Multiplier) you won't Lug the Engine, so don't really need 1st gear for a normal start, and it gives the Tip S better MPG...
Happy Motoring!... Jim'99
