					Originally Posted by dagdisco03  The one with tape on the tips Pic#2 is a mod that's not OEM on any car.  I'm about to mod mine but have not done it yet.  I'm going to add a small 2" U pipe on the back side to go from the second chamber to the outer chamber on each side.  The car will look OEM from the outside. |
I guess I can imagine the second one not being OEM, but it doesn't look like something a hobbyist came up with either. In any case, if you're correct and all OEM cans are like pic 1, then my hack will be easier-- like yours, except I'm going to do electric valves in the bypass piping so I can adjust the noise level as desired.
