Not the pad on top of the instrument cover
There might be some confusion as to what I am wanting to buy. It is not the padded piece that goes on top of the instrument cluster. It is the plastic housing that contains the instrument cluster. The cluster housing consists of three main pieces plastic. The three pieces are held together by metal clips on each end of the cluster, plus a few screws. Rarely does one need to open this up.
The three pieces consist of
1.) a molded black plastic back cover,
2.) a molded plastic mounting plate that the circuit board and gages are mounted to (this piece can be either black or white depending upon the color of the gages.) and
3.) the molded plastic front cover that holds the clear gage covers.
I need number 1 and 3.
Hope someone can help. Thanks.
