Old 02-08-2006, 09:04 AM   #1
MNBoxster
Hi,
I hate to disagree with Perfectlap, but handling can be adversely affected by the Tires. The alignment won't be affected, but the handling, especially vibration issues at Speed can well come from a set of Tires, New or otherwise
No Tire is perfectly round, nor is any wheel, they each have a High and Low side to them, an eccentricity. The inherent eccentricity is called Runout. A proper Tire Shop will mount the Tire so that it's Low Spot matches the Wheels High Spot, this reduces, but may not entirely eliminate the Runout problem, leaving some vibration in the Tire at some speeds.
In addition, a Tire is a Dynamic thing. It changes due to Forces exerted on it. A Tire may have a minimal Runout when not under load, but, due to variations in construction, may actually become more out-of-round once it is loaded.
This is why I recommend a Dynamic Balance of the Wheels/Tires. This differs significantly from a standard Spin Balancing. A Dynamic Balance puts the Wheel/Tire under Force by spinning it against a Loaded Road Wheel. This allows the Tire to be observed as it would actually run on the Street. Typically, Wheels/Tires are observed and corrected for 50MPH, but any speed can be selected and checked.
A Company named Hunter Engineering manufactures this type of equipment, the latest generation being the GSP9700. I would not have my Wheels/Tires mounted and Balanced by a shop which does not use this equipment. You can see a detailed explanation of all this here: http://www.gsp9700.com/pub/technical/5098T/5098T.pdf
One problem is that not every Wheel/Tire combination can be made to work. There are limits to the eccentricities which can be adjusted for. I once bought a set of Dunlop SP Sport 8000 Tires for my Esprit from Tire Rack and two of them were out of Spec when checked on the GSP9700 (which gives you a Graphic Printout of the Tire, it's Specs and it's Footprint). The Shop refused to mount the Tires as they have high Quality Control on their work.
I had a heck of a time getting Tire Rack to exchange them. They don't check the Tires for this and so did not consider it to be faulty. It took two more pairs from them to get it right.
Interestingly, the Manager said that they see much more of these problems with Tires bought from Discount Houses such as Discount Tire, Tire Rack, Costco and the like, over those sold by the Tire Manufacturers' Outlets and Franchises, by a factor of about 5:1, a significant amount. He speculated that the Tire Manufacturers keep the best Tires for their own Outlets and Franchises...
Happy Motoring!... Jim'99
