When I replaced the AOS I also found that the oil filler tube was leaking. This is sometimes caused by a failing AOS. Excessive vacuum causes the hose to compress and crack.
I think it also caused a vacuum leak because my 1128 and 1130 codes have disappeared since replacing the tube This would only explain the external oil
BTW Its a pain to replace.
