Old 10-25-2013, 11:45 AM   #20
rijc99
Originally Posted by Brockmeister View Post
Install was done this weekend. I was going to it on Thursday, but I only had a 24mm deep socket, and you need a regular. Took me a while to get the pulley seated properly and tightened up so it didn't wobble. I cut the boss off with a sawzall, it only took about 15 minutes, no problem. Once I did this I put it all back together and went for a spin. You can definitely tell it has more grunt than it did before. I does accelerate better in all gears, and gets to 100mph in a more timely fashion. Not a bad mod at all!
Is the sawzall step required for all makes of UDP? Will it be pretty obvious how much or where needs grinding?
Thanks.
rijc99 is offline   Reply With Quote
