There are 2 cables. One is controlled by forward and backward movement of the shifter, the other by side to side movement. It sounds like there's a worn bushing or broken spring related to one cable. You could pull out the console and check it out or order a new shifter. Many have replaced the original with a 997 or 997 short shifter and found that they're much smoother and don't feel as cheap.
