Old 10-24-2013, 08:16 AM   #11
southernstar
TuneRS, I can fully understand why you would not want to get involved with a discussion of competing technologies except through PM or email. Indeed, one might even consider a refusal to get involved in what will inevitably devolve into public mud-slinging as taking the 'high road.' Neverhteless, from a reading of this entire thread I do not believe that anyone has suggested that DOF is a bearing replacement - although most posters who reference the system are suggesting both a bearing replacement/upgrade AND DOF where possible - i.e., in all but the later large single bearing engines in which the bearing cannot be replaced without engine tear-down.
Frankly, I and various other posters have been not only interested in the DOF technology, but supportive of the concept. To date it would seem that the only concerns expressed (apart from, like the LN Solution, the understandable lack of real-world use in a large number of cars over a number of years) is with respect to two issues:
1. potential oil pressure loss/differing oil flow characteristics in the engine;
2. potential aeration of the oil and the effects on the A/OS and upon lubrication generally.
I and others have already opined that, as the engines are engineered to take into account significant variations in oil pressure, the small amount of oil being directed to this bearing should not have deleterious effects upon lubrication of other parts of the engine. Certainly your successful testing even in racing environments would tend to support this.
I and others have also opined that, with oil entering under pressure through a line that should not contain air, aeration should not be a problem. Nevertheless, I and others have also encouraged a test that would compare oil on comparable vehicles both with, and without DOF, after equivalent hard runs. While I suspect your technology would pass with flying colors, a test/deomonstration should go a long ways towards dispelling concerns that are clearly held by a number of prospective customers.
Surely, answers to these questions in a public setting can only benefit your company. You would not be required to attack other products as, from what I can see, your DOF is the sole product on the market that is attacking the problem from a lubrication, rather than bearing design/construction approach. It is also the only product that can be used on the later, large diameter single-row bearings - which, in spite of some suggstions to the contrary, have suffered a significant number of failures even though the engines are newer and in some cases, much newer than the earlier single-row and dual-row bearings. I think we can also safely assume that without adequate lubrication, the number and percentage of failures in those large bearings will go up with increasing mileage and the passage of time.
Is splash lubricaton of the IMS bearing through the removal of the outer seal adequate in all driving conditions? The fact that this is apparently the only recommendation made by Excellence magazine is in no way conclusive; indeed, in a magazine that relies upon advertising revenue, it is understandable that they would not support any one technology over another. I also find it difficult to believe that if the solution was that simple, Porshce would not have merely removed the outer seal in later vehicles and recommended the same in a service bulletin on cars that had suffered failures, or required a clutch replacement.
In sum, this thread has shown that there is a great deal of interest in DOF technology even though there are some questions that remain unanswered. I, for one, believe that you would be doing this group of potential customers and yourself a real service by attempting to answer them. Don't take the bait - don't engage in mud-slinging with posts from competing technologes who are obviously proceeding from a biased perspective. Do, however, take this opportunity to not only explain your technology and to extol its virtues, but to answer some legitimate questions which have already been posed.
Brad
southernstar is offline   Reply With Quote
