Old 10-21-2013, 01:27 PM   #11
Kirk
Originally Posted by Kirk View Post
But ceramic bearings in general are designed for all forms of oil lubrication. Since you are providing some technical detail regarding your ceramic bearing would you mind providing some better detail on why the LN Retrofit does not work with direct oil feed?
Given my last post with the photos I will pose this question again... if I don't feel comfortable relying just on oil bath and oil splash lubrication, what is wrong with direct oil feed to a ceramic ball bearing - specifically the LN Engineering bearing??? Wouldn't the DOF allow the bearing to run with less wear and cooler? Wouldn't it remove variable lubrication and make it more consistent? These all seem like good things to me, and I really can't see aeration and system pressure losses as being significant down sides. So what exactly is the problem with DOF on a ceramic bearing?
Kirk Bristol
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
